BORG Posted October 29, 2008 Share Posted October 29, 2008 Also in the Ford Fusion/Milan. Aggressive Deceleration Fuel Shut-off. The 3.0-liter V-6 also regulates its gas consumption by using aggressive deceleration fuel shut-off for an efficiency improvement of approximately 1 percent. When the driver releases the accelerator pedal to slow down, the system temporarily turns off the fuel. The flow of fuel seamlessly resumes when the vehicle reaches a low speed or when the driver accelerates again. The system uses the transmission to keep the engine running at a low, more efficient operating point whenever possible. This system will be added to the 2.5-liter lineup later in the 2010 model year. Quote Link to comment Share on other sites More sharing options...
Paul Selby Posted October 30, 2008 Share Posted October 30, 2008 Wasn't this supposed to be on the '09 F-150 also? Quote Link to comment Share on other sites More sharing options...
fordpower02 Posted October 30, 2008 Share Posted October 30, 2008 Wasn't this supposed to be on the '09 F-150 also? Your right. And its actually used on all Ford vehicles. Quote Link to comment Share on other sites More sharing options...
BORG Posted October 30, 2008 Author Share Posted October 30, 2008 Keeping up with the across the line tech propagation is a full-time job . Quote Link to comment Share on other sites More sharing options...
goinbroke2 Posted October 30, 2008 Share Posted October 30, 2008 Had a diesel super duty that did that at least three years ago. Going down a hill it would get quiet, touch the pedal and the rattle would be back. First time I ever saw/heard of it. Even if you take foot off throttle at 60mph and then step on it again you got a rrrr.....rrrr....rrrr Say three years ago and the truck was fairly new so a 04-05 SD diesel. Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted October 30, 2008 Share Posted October 30, 2008 1% gain in fuel efficiency!!!!! That's 1/5th of what you get from properly inflated tires!!!!! Quote Link to comment Share on other sites More sharing options...
blazerdude20 Posted October 30, 2008 Share Posted October 30, 2008 1% gain in fuel efficiency!!!!! That's 1/5th of what you get from properly inflated tires!!!!! but, but, but that takes effort. besides if everyone inflated their tires then AAA would probably go out of buisness. Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted October 30, 2008 Share Posted October 30, 2008 1% gain in fuel efficiency!!!!! That's 1/5th of what you get from properly inflated tires!!!!! But it's 1% that is taken out of the hands of vehicle owners. Every little bit helps! Quote Link to comment Share on other sites More sharing options...
