rockridge Posted November 1, 2007 Share Posted November 1, 2007 Does anyone know what the part number is for the daytime running light module? This would be for a 2008 F-350. For 2003 it was either F6SZ-13B218-AA or F8AZ-13B218-AA, but it's my understanding the part number has changed. Any help would be appreciated... Thanks! Quote Link to comment Share on other sites More sharing options...
b1rnvv86 Posted November 5, 2007 Share Posted November 5, 2007 no module require, sjb to be configure Quote Link to comment Share on other sites More sharing options...
jam116 Posted November 7, 2007 Share Posted November 7, 2007 no module require, sjb to be configure Please explain.. I would like to have the day time running lights..... Thank you for your assistance. :stats: Quote Link to comment Share on other sites More sharing options...
rockridge Posted November 13, 2007 Author Share Posted November 13, 2007 (edited) no module require, sjb to be configure Please explain this comment,..... If no module is required, is there a wiring diagram available? The latest "advertising" from Ford indicates this option is available, but even my dealer and parts dept. manager can't find anymore information. Any further information would be helpful! Thanks! Edited November 13, 2007 by rockridge Quote Link to comment Share on other sites More sharing options...
jam116 Posted November 15, 2007 Share Posted November 15, 2007 Please explain this comment,..... If no module is required, is there a wiring diagram available? The latest "advertising" from Ford indicates this option is available, but even my dealer and parts dept. manager can't find anymore information. Any further information would be helpful! Thanks! Did you ever find out what he was talking about with the daytime running lights Quote Link to comment Share on other sites More sharing options...
EtniesRIT Posted November 15, 2007 Share Posted November 15, 2007 Did you ever find out what he was talking about with the daytime running lights DRLs on the 2008 Super Duty are controlled by the Smart junction box (SJB), which means the option just has to be enabled in the computer by a dealer. Quote Link to comment Share on other sites More sharing options...
b1rnvv86 Posted November 15, 2007 Share Posted November 15, 2007 SECTION 417-01: Exterior Lighting 2008 F-Super Duty 250-550 Workshop Manual DIAGNOSIS AND TESTING Procedure revision date: 10/04/2007 -------------------------------------------------------------------------------- Daytime Running Lamps (DRL) Printable View (100 KB) Special Tool(s) Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool Principles of Operation NOTE: The smart junction box (SJB) is also known as the generic electronic module (GEM). NOTE: When installing a new SJB, it must be configured for this feature, if originally equipped. Refer to Section 418-01. The SJB controls the DRL by using various inputs to determine whether or not the DRL should be illuminated. These inputs include: Ignition switch position Headlamp switch position Headlamps on or off Transmission gear selection (automatic transmission) Parking brake applied or released (manual transmission) When the DRL is active, the SJB provides a pulse-width modulated (PWM) voltage to the low beam headlamps. This illuminates the headlamps at a reduced intensity. Quote Link to comment Share on other sites More sharing options...
rockridge Posted November 15, 2007 Author Share Posted November 15, 2007 Thank you b1rnvv86... That is exactly what I was looking for!!!! Ed Quote Link to comment Share on other sites More sharing options...
b1rnvv86 Posted November 15, 2007 Share Posted November 15, 2007 Thank you b1rnvv86... That is exactly what I was looking for!!!! Ed you r welcome--- cela m a fait plaisir. toujours a votre disposition pour d autres informations--- Always at your disposal for further information normallement votre concessionnaire devrais etre au fait de cette procedure --- Normally your dealer should be aware of this procedure Quote Link to comment Share on other sites More sharing options...
jam116 Posted December 6, 2007 Share Posted December 6, 2007 SECTION 417-01: Exterior Lighting 2008 F-Super Duty 250-550 Workshop Manual DIAGNOSIS AND TESTING Procedure revision date: 10/04/2007 -------------------------------------------------------------------------------- Daytime Running Lamps (DRL) Printable View (100 KB) Special Tool(s) Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool Principles of Operation NOTE: The smart junction box (SJB) is also known as the generic electronic module (GEM). NOTE: When installing a new SJB, it must be configured for this feature, if originally equipped. Refer to Section 418-01. The SJB controls the DRL by using various inputs to determine whether or not the DRL should be illuminated. These inputs include: Ignition switch position Headlamp switch position Headlamps on or off Transmission gear selection (automatic transmission) Parking brake applied or released (manual transmission) When the DRL is active, the SJB provides a pulse-width modulated (PWM) voltage to the low beam headlamps. This illuminates the headlamps at a reduced intensity. Dealer turned this on for my F-450 today..Labor cost of $79.95. All labor no parts... Quote Link to comment Share on other sites More sharing options...
ntenufsun Posted December 7, 2007 Share Posted December 7, 2007 Why don't you just cover the photocell on the dash with some electrical tape and then you'll never have to touch your light switch again? That's what I did. Jeff Quote Link to comment Share on other sites More sharing options...
