wind noise
real_texan
I recently took my 2007 exp. into the dealer again for the wind noise coming from the front windows. I had asked if they performed the tsb on the door window run. They stated its coming from the mirrows instead and there is a new tsb for it. I was wondering does anyone have a copy of the new tsb for the mirrows.
Edited by real_texan
While talking to the shop foreman about my brakes I asked him about the wind noise. He said they know it's a big problem. It occurs on the Explorers as well. Something to do with how the plastic mates to the metal. As of last week he did not know of a TSB, but he didn't look it up either. Anymore info would be great.
FORD: 2007 Expedition
LINCOLN: 2007 Navigator
ISSUE:
Some 2007 Expedition and Navigator vehicles built before 05/07/2007 may exhibit wind noise around the exterior driver and/or passenger doors. This may be most noticeable near the A-pillar area of the door.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: IF THE VEHICLE BUILD DATE IS ON OR AFTER 5/07/2007, THIS TSB DOES NOT APPLY. CONTINUE WITH NORMAL WORKSHOP MANUAL DIAGNOSTICS.
Tape the trailing edge of the mirror sail down to the front window glass from the tip of the mirror sail to the belt molding.
If the noise goes away, replace the mirror on the effected side. Both mirrors do not have to be replaced.
If the noise does not go away, continue with normal Workshop Manual (WSM), Section 100-04 diagnostics.
PART NUMBER PART NAME
8L1Z-17682-AA Mirror - Expedition-Passenger - Power/Heated Convex - Middle Eastern Countries
8L1Z-17682-BA Mirror - Expedition-Passenger - Power Heat/Memory
8L1Z-17682-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17682-DA Mirror - Expedition-Passenger - Power/Heated Convex
7L1Z-17682-EA Mirror - Expedition-Passenger - Power
7L1Z-17682-FA Mirror - Expedition-Passenger - Power - Middle Eastern Countries
8L1Z-17682-GA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold / Expedition-Power Fold, Power Adjust
8L1Z-17682-HA Mirror - Expedition-Passenger - Power Fold/Power Adjust - Middle Eastern Countries
8L7Z-17682-AA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold
8L7Z-17682-BA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold - Middle Eastern Countries
8L1Z-17683-AA Mirror - Expedition-Driver - Power/Heated
8L1Z-17683-BA Mirror - Expedition-Driver - Power/Memory/Heat
7L1Z-17683-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17683-DA Mirror - Navigator-Drivers - Power Heat/Memory/Power Fold / Expedition-Power Fold/Power Adjust
8L7Z-17683-AA Mirror - Navigator-Drivers - Side Power Heat/Memory/Power Fold
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071615A 2007 Expedition/Navigator: Replace One Mirror, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 0.7 Hr.
071615B 2007 Expedition/Navigator: Replace Both Mirrors, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 1.1 Hrs.
071615C 2007 Expedition/Navigator: Extra Time To Paint One Mirror, This Labor Operation Should Be Claimed With Labor Operation A (Do Not Use With P101, P17) 1.0 Hr.
071615D 2007 Expedition/Navigator: Extra Time To Paint Both Mirror, This Labor Operation Should Be Claimed With Labor Operation B (Do Not Use With P101, P17) 1.5 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
17682 07
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
Thanks!
We are still having wind noise of the drivers side even after the dealer did the first TSB for the window trim stuff.
This sounds like I can tape up the outside mirrow to test, before I waste a trip to the dealer.
Can anybody suggest exactly what Ford means by trailing edge of the mirror sail??
And what kind of tape to use?
Thanks!
It's this part Window.jpg and I would use a wide masking tape, tan or the blue stuff. I am going to try it today.
  • 1 month later...
